Lawn Mower trouble shooting question
Rocky1231
I just bought a troy built push mower off Craigslist. It wasn't running but Ive put a new air filter, cleaned the gas tank, and carb. However, it isn't running still. I put b12 chem tool in and it fired up but after I let it run through I put new gas in and now wont run? Do y'all have any idea on why this is?
motoman
Rocky, Dig further in this forum "search." There are tons of tips. When you do this , tell the forum and someone will probably respond.
Rocky1231
Hey thanks for the response. Do you mean search those questions, they probably already been asked?
treezandgrass
I have a Troy Built self propelled an my float gets stuck from time to time for no apparent reason. I just remove the bowl and spray some carb cleaner on and around the float and it runs good as new.
motoman
Rocky, yes, many problems are stated and responses and tips posted. Find some tips, try them, and then post your results again, even if still stumped.
Fish
Rocky isn't stumped, just bored....
MRCo.
Briggs engine? Does it have a primer! If you take the air filter off and hit the primer. Is it pulling gas? Is it an auto choke model? If so, is the choke working?
Rocky1231
Hey thanks for the reply. Its is a briggs and strat motor. It does not have a primer on it.
