turfboy1997
- Apr 24, 2012
- 26
- 164
I had tried everything to my 10424 to quit surging and it still wanted to surge after three carb cleanings. Today as a last resort i changed the throttle plate to the one with a larger hole and still surging. Then i got Briggs part number 801308 and replaced the pilot jet. When i started that motor it roared to life with absolutely no surging and no smoking! If any of you have duraforce engines and have not performed this upgrade it will blow your mind the difference. It burbles like an F until you sink it in some thick grass and then i have never heard the governor on an f kick in like the duraforce did today. Every duraforce that i get will have this upgrade performed. The best part is you don't even have to pull the carb to do it because the jet is on the outside left of the carb. I don't know if anyone has started a tread about this in the past but just thought i would share!
