I did search for other threads with this issue. I hope this isn't a redundant thread.
I recently installed the mulching blades and the mulch cover to this mower (42" deck) The cut is terrible. I've ensured that the both blades are turning and the spindles aren't bent nor is the deck cracked, but man is it an uneven cut. I do believe I adjusted the deck to make it even, in my search i read a comment on another forum mentioning that the front of the deck needs to be below the back of the deck for proper cut. Is this true?
HELP
HELP
