I need to change the Traction/Wheel drive belt on my John Deere L130. I appears that I need to remove the gear from the bottom of the steering shaft so that I can put the new belt on. Any suggestions on the procedure to replace the belt. My old belt is not broken, but worn and cracked.
Steve
Steve
