sheetmetalbabe
- Apr 24, 2015
- 4
- 33
Well, I have posted this problem before and thought it was fixed, NOT. Sometimes I can mow a little and sometimes a lot.
It will cut for a while then surge and die. The gas cap is not clogged, no debris blocking air intake, new air filter, oil filter, fuel pump, voltage regulator. No grass packed under the deck.
Some have suggested bad coils but after the fuel pump replacement I did mow 8 acres with no problem so would I have been able to do that if the coils were bad?
I did notice when it dies, the fuel filter is completely full of gas? That's why I replaced the fuel pump thinking it wasn't keeping up.
I just mowed about 500 feet and it died?? Any thoughts would be appreciated.
Thanks
Thanks
