OK,, JD, brain trust,,,, question and a favor,, this mower is being brought back from the dead, :laughing:, it was a victim of hurricane Ike,, friend of mine gave it to me, just a little TLC to bring it back so far, totally stripped it, including motor tear down,, everything pretty straight forward, but what is bad is the wiring harness, the main one from the dash to the motor,,, just a couple of connectors where the wires corroded and fell out from being flooded with salt water.
I need a picture of the harness showing the different colors of the wires and which connector they go to,,, ign. switch wires are fine,,, it's just the lower level wires where they got corroded and fell out, so I don't know which connector they go into ,,, so if somebody has a yr. model close to this one, could you snap a pic and post it, I can rebuild it.
Thanks,
Paul
Thanks,
Paul
