Hey All.
I have a kubota F3060 out front deck mower with a 72 inch cut.
My problem is with the orbitrol steering control unit ( scu )
I dissmantled the unit to replace some leaking seals. I have since reassembled as per the eaton assembly web page making sure the timing is set as per the manual.
now the wheels will quickly turn from lock to lock with only minimum steering wheel movement.
What have i got wrong . I have checked and rechecked the assembly. Is the timing on these particular models different from other eaton summitomo boxes.
Please help me as this is driving me crazy.
the steering unit model is RU051A080F1A 516
thanks every one
thanks every one
