Kubota BX1860
Terry
Should I push snow from the rear or spend the money for the front lift?
KennyV
Love Kubotas... But you are really on the small end of the lot...
Then again it's a 4 wheel drive Diesel. It should have the ability to do well with a rear blade... I am not sure how well the loader attachment will do, you might look into a front mounted snow plow... :smile:KennyV
Terry
The front upgrade (valve and hitch) runs around 2000 bucks, but if FEL or anything is needed in the front later, it saves to get the valve and hitch intalled by the factory. I just wondered how it wound be pushing snow in reverse with the blade in the back.
KennyV
...I just wondered how it wound be pushing snow in reverse with the blade in the back.
When pushing snow in reverse... You Will eventually get a BIG pain in the neck... I did it for years like that before I got something that could push anything while facing front... :smile:KennyV
Briana
WELCOME to LMF
I moved your thread to the Kubota Forum. :smile:
