Sometimes the engine will start as soon as you turn the key. Other times you must turn engine by hand until it won't turn any further, then turn key and it will start. Already reset valves. Runs fine. just start problem
definitely a pattern.Yes, it happens like you said, starts when cold but have to turn by hand when hot.
