kohler runs at very low idle wont rev up
craney89
Hello, here's another one. I have a kohler on a toro recycler. xt675-2034 it wouldn't start so I drained the fuel system and removed and cleaned the carb. put it all back together and it started right up. Problem is it just barely runs. doesn't rev up. did I put together wrong, is it a gasket issue?
Throttle binding or governor spring disconnected or not connected correctly.
pictures tell a thousand words.
model numbers locate correct parts diagrams
We have neither
