kohler engine issues
greenelephant
hello everyone
I have a morbark wood chipper with a kohler command 25hp CH25S engine. The issue is the original carburetor is a keihin 24-053-34 carburetor which comes in 2 parts. I have lost one of the halves of the carburetor rendering it useless. My question is I can source a kohler command CH730 carburetor cheaply. Will this carburetor work on a kohler command 25HP CH25S engine? thanks :)
Your carb on your CH25s and CH730 used on the morbark are different. Actually the cost of the carb used on the CH730 is higher retail than your carb.
