Kohler CV16s stator replacement
mikesignal
Hi all. I'm trying to replace my stator and voltage regulator. Does it matter which way the wires go on the regulator from the stator, and then from the regulator to the wiring harness? The stator is not labeled , only the regulator is labeled, AC, B+, and AC. Thanks
The white stator wires can go on either outside prong on the regulator. The purple wire goes on the center B+ terminal which connects to battery power.
