Kohler CV15s runs at full throttle
jcd302
My brother picked up a JD LT150 with a CV15S that will only run at full throttle. The throttle moves but the RPMs stay up there... unless you slightly choke it, then it will idle down, but you have to play with the lever to keep it running. I played with the governor lever and there is no change in the RPMs.
Seems to me like a carb issue.
The elderly man he bought it from said there was a bang and there was smoke. It has sat for about a year, but a shot of starting fluid and it fired up, witht the aforementioned high RPMs.
Thoughts?
jcd302
screws came off the butterfly for the throttle. Still runs good, just don't know where the screws went.
Either they are stuck to the head or piston, or they went out the exhaust into the muffler
