Kohler Courage PRO 27 exhaust bolt missing.
GODZILLA1
I have a Kohler pro 27 that keeps losing one of the exhaust bolts and my bolt supply is out. What size are they (I looked in the service manual but no luck) and how can I prevent it from falling out, now the second time. I do not want to use the wrong product on the alum head.
The IPL for the mower should tell you what they used. But the SM does indicate if they are cap screws that they would be 5/16-18 type. Probably 3/4" in length or at least that is my noted size here for the Courage singles. Suggest using a lock washer and torque to 150 in/lbs.
GODZILLA1
Forgive my ignorence but what does IPL stand for? The bolts are allen wrench type and I will try the lock washer Thanks.
IPL stands for individual parts list.
Those screws are called socket cap screws.
IPL > Illustrated Part List
hlw49
Cub Cadet 710-1314A
Screw, Socket Head, 5/16-18, .750 Muffler bolts are usually listed in the IPL for the equipment
GODZILLA1
Where did you see the cap screws in the service manual? I cannot locate them. This is a 2 cylinder 27 kohler courage pro too.
Should something like the SV740-???? Look under Muffler.
