I put one off on a John Deere 717, it finally blew up due to lack of oil and stupidity. If I could go back I would fix the leak as I ended up parting the mower out. What is this engine on? When I took the mower apart, the engine was actually easy to remove, so im guessing that seal replacement shouldn't be to bad.
