Kabota zd331 with sever oil leak from fuel pump
puksta
Yes, I was mowing in high grass and was not keeping a close eye on the temp gauge. It looks like i blew a seal off the back of my fuel pump and am now pumping oil out at high rpm. Can anyone help with the name of this part or a part number? How to instal would be much appreciated too. TIA
lugbolt
can you post a picture? I have a feeling you're talking about the plug that is pressed into the back of the block, below the injection pump.
By the way there is only one "A" in kUbota.
