- Nov 29, 2014
- Threads
- 64
- 24,705
This saw has been busting my balls for a week.
Owners rings 4 times a day chasing it.
Shame he did not spend the same time servicing it.
It is fitted with a Walbro RWJ-5 carb for which I can find no service information.
When I got it it would start easy & run no more then 3/4 throttle
It just cut out, no lean running speed increase, no 4 stroking rich indication, it just cut off.
Run the carb through the ultrasound checked for flow through all the orifices working well including all 3 of the start / idle holes.
Owner had the idle screw right in till the throttle lever was level with the bottom of the screwdriver slot so assumed it was idleing on the high speed jet.
Put a kit through it replaced every thing except the needle as it had a Vitton tipped needle & the genuine walbro kit comes with a solid brass brass one.
Needle holds pressure & unseats when I blow air through the venturi so it appears to be functioning normally.
My carb repair kit does not have needle height for a RWJ marked on it so I have no idea what the needle height should be.
I also have no idea what factory start settings on the H & L jets should be and have just about worn out the elbow starting the thing.
walbro's web site does not list the RWJ series let alone have any service info and Husqvarna only have parts books & owners manuals which all say "fixed jets "
When I got it it was H 1.25 & L 0.75 turns but now it is ( hopefully ) clean those don't work.
It was on a concrete saw , muffler is clean, compression is good , cylinder & piston are clean brain is just about exhausted.
Any one have any ideas ?
