johndeerewont start
mr.wrench
im new to this website not sure I have jd d120 I put it away last fall did everything to winteriseit then try to start it to to get stabilizer through the block -then it wouldn't start. so come spring try to start nothing some bud said it sonded like the starter- starter solonied-+tuneup kit now it will start sometimes when it does the starter get hot -starter wire ger hot then if I jiggle switch it will start sometimes thanks mr. wrench
