Had this problem last year but learned how to beat on carburetor bowl and start solenoid in bottom of float bowl. Before I ever try to start I look at the in line fuel filter bowl and it is clear full, don't believe this is normal. It will start and run for approximately 8 seconds and die, won't start again until I beat on bowl and start turning engine over and fuel will start moving thru filter. Will start and run OK from then.
Last night it started and ran approximately 1 and 1/2 minutes and died. Fuel filter was half full of fuel like it should be.
Any ideals? thanks
Any ideals? thanks
