chevyman984
- Jun 23, 2012
- 7
- 39
I got a John Deere D105 automatic lawnmower. 42 inch. Today i was mowing an i shifted into reverse, backed up, and it was in reverse to stay. I had to go backwards all the way back to the house. Now i discovered it will go out of reverse if you pull back on the "go pedal" all the way. Is the transmission shot? It will move forward and backward if you fiddle with the pedal. It also started moving forward in neutral. Usually when you put it in neutral and let off the clutch, it was practically setting the parking brake. And when you push on the pedal it was rock hard. Now when you push the pedal in neutral it starts rolling then the gears catch and it moves.(i discovered that by accident). Its a shame because the warranty just ran out 6 hours ago. Ive had it one year and it has 126 hours. Its been well maintained also. Thanks guys and sorry this is so long!
