john deere L 100 - cannot find fuel pump vacuum connection
Olustee bus
  • / john deere L 100 - cannot find fuel pump vacuum connection
For the life of me. I have not disassembled any thing except the fuel pump. I think the vacuum tube may have fallen off during the process, I don't know. Can anyone describe where it is located. I have searched many images with no real success. IT is a Briggs and Stratton 17 hp, single cyl.
Do you have any idea how many 17 hp, single cylinder model engines Briggs makes. We need the model type and code numbers before we can help you.
Olustee bus
I will get it this afternoon. Any help will be appreciated.
It should be a 31F707 series engine. Fuel vacuum line looks a 1/4" fuel is attached to dip stick tube.
Olustee bus
Thank you very much. I have decided to install an electric pump and if that does not work I will go to the dipstick
