DSteve34
- Oct 17, 2017
- 3
- 10
I have a JD 425 in which the oil seems to rise over time. The coolant levels seem to stay the same so I figured no coolant was getting into the engine. I do wonder if gas is getting through the carb and into the crankcase while it is sitting. Is there any common problems with these engines that causes this? The engine is a kawasaki liquid cooled 20 hp horizontal shaft. Any info appreciated.
