Your fuel supply can be cut-of is the needle valve not stuck check float level and needle valveSorry I hit the send button on accident
I changed the oil seal and hydro fan and went fire it up and it would not pop off. Cleaned the carb out and now runs but it runs a little rich and dies after 5-10 seconds. Can anybody tell me what's wrong I know it's in the carb but I don't know what it is.
Sent from my droid 4 using LMF
I checked the needle valve and sure enough it was not connected to the float, reconnected it but i ran out of time to put the carb on.
Thank you
Dose any body think this is ok or not i think it will work for now but i'm going to call the dealer tomorrow and get another one. Is that pipe coming up stock or not? I just need another opinion on this it looks like the hose broke and they just put that pipe in place of that section of hose.
