The mower just suddenly cut off while I was mowing, like it had run out of gas. I have replaced all of the gas in the tank and lines. I have checked to make sure that fuel is getting to the carburetor. I have taken the carburetor apart and cleaned it. I have bypassed the seat switch to be sure it was not cutting the mower off by not working.
It will fire up when I try to start it and run for a few seconds and then cut out. It's like its not getting gas, but I'm sure there is no debris in the carburetor.
I'm wondering if another cut off switch could be causing a problem and disrupting the flow of fuel to the carburetor?
I would suspect the fuel pump, but when I turned the motor over and took it off the carburetor, it seemed to provide a plentiful supply.
I have a feeling it is something simple, not major, the motor is only about 3 years old.
Thanks for any suggestions.
