I'm working on the above mower with a B&S 16 HP twin model #402707013101 and I can't get the battery to charge. The battery reads 12.7 volts while running but it will decrease as the mower runs.
I've checked all the wiring, made sure that the cables are free of rust but I can't figure out how the battery charges.
I have one green wire coming out from under the flywheel and it shows 12.7 volts. There is another wire coming out from under the flywheel and it goes to the coil which I assume is the ground.
Can someone give me some help as to what to look for?
The battery is new and fully charged and tested and I can find no fuses to check. This is an old mower that a friend got for free.
Thanks, Mike
Thanks, Mike
