JD LX176 Grease Points
man00
I could only find two in the front axles..are there more?
Front king pins, wheel hubs ( inside ) front cross member pivot
The pivot nipple is under the arm and often broken off
They are shown on the parts diagrams on the JD web page and also in the owners manual accessable from the web site
Usually you can only print out 1 section at a time ( PIA)
man00
Looked at the parts diagrams again and under the tractor, only found two on the axle one on each side. None on the hubs and none on the pivot
thanks
