Hello and greetings from the UK. I was hoping somebody may be able to offer me some advice on a fault I have with my JD LT166 fitted with a Briggs and Stratton 16HP engine.
When I go to start it there is just a click, but it won't fire up. When I charge the battery for a bit eventually I can get it to start and it runs no problem. This screamed battery failure to me so I replaced it with an identical and brand new one. Unfortunately this has not resolved the issue. Indeed, now I can't get it to start at all, just the clicking. Both batteries appear to have a charge when tested (they're "in the green" on my tester, not checked full output).
I've just serviced it (oil and filter change, air and fuel filters and spark plugs changed too), so I'm confident it is not a fuel-flow issue.
Has anybody had any experience of anything like this before? Any help would be much appreciated.
Thanks in advance.
Ben
Thanks in advance.
Ben
