RidleyJ329
- Apr 21, 2015
- 1
- 2
Hey guys, just joined. Got a John Deere that has been in storage for about two years. I recently put drained the old fuel out and added some fresh fuel along with some Gumout injection/carb cleaner. This was after i removed the carburetor and took it apart to clean the old fuel and the lime out of it. Ive also sprayed it real good with carb cleaner. I've also changed the spark plug. when i spray some Gumout starter fluid in the air intake it starts but dies shortly after. No sure what else to try. im gonna try to include some pictures if it helps any. As you can see, there is some kind of plastic "Z" shaped item that goes from the carb to the air filter and to the engine itself. idk if im missing something but how do i get the fuel to go down from the gas tank then back up into the engine?
