I recently acquired a 1995 John Deere 325. There is a LOT of play in the steering. This model has manual steering. The shaft goes into a sealed gear box. The gear box has a threaded plug toward the top so I'm assuming it's filled with fluid/lubricant.
Before I start taking things apart looking for worn internal parts, are there any adjustment points that I should know about? Any other suggestions?
