JD 320 leaving burn mark in lawn when stopped
jyatson
Any solution to a JD 320 leaving heat burn marks on lawn when left running in place even for less than a minute?
Repair/replace muffler if it really is a heat burn.
Adjust the front deck height if it is a helicopter burn ( swirl )
redmondjp
Check muffler exhaust pipe. If it discharges down, this will happen. It should point either towards the front or the side (or in-between).
