I just picked this up from a local guy who said it had a oil leak, we got it to start but it would die after a few so I figured it was a fuel issue.
Got it home and removed the carb and cleaned it up and put it back together. Fired right up. I liked the sound of this motor, quiter than the briggs and stratton Toro I have.
anyhow I decide to go out front and run it a little. I engage the drive belt and it spins..its soon evident the oil leak is a little worse that I expected and its dripping somewhere out the bottom of the deck but its hard to see. the mower moves when engaged and I manage to get it to 5th and rolling all over the driveway. I engage the blade and it works as well.
By this time more oil has leaked and it appears the drive belt isnt getting traction because the mower no longer wants to move. I was starting to worry about the oil sO i killed it and put it up. I tried to look at the leak but wasnt able to. the carb was leaking and I decided to stop before the whole thing caught fire and burned down the house or something.
I was happy for all of 5 minutes till I saw the oil. I am hoping the oil is causing the wheels to not engage or maybe the belt is stretched . it spins but it stopped driving the wheels.
how hard is this going to be to fix the leak? I was told some seal was leaking. I have never worked on a mower until today when I yanked off the carb to clean it. I really like this mower I just cant afford to pay for it to be fixed. I am pretty mechanical..work on my own cars and should be able to do this..
luckily no rush to fix as I can use the toro...but I like the JD better
