Attachments Installing LED lights
cubcadet1
I have a 2016 Z Force L that I installed new LED lights on. I took the simple approach of wiring directly to the battery with the positive side wired through a switch and a 3 amp inline fuse. After installation I flipped the switch, the light came on, and I said success! But wait. When I start the engine and then switch the light on it flashes and goes out. I blue the fuse. Not only did I blow a 3 amp fuse but I also blew a 5 amp and 10 amp fuse. I have watched several You Tube videos and my installation is just like what I've seen on You Tube. But theirs worked. Sure would appreciate any help to help solve this problem. Thanks.
A wire didn't get next to a spinning pulley and get cut and now is grounding out causing a short.
