Eugbug
- Jan 8, 2012
- 9
- 20
As far as I can make out the model number is E-58002A. The cowl is also marked SPT50 which I presume means Spectra 50. The engine was made in '97. The ignition coil has failed, so what's the difference between all the different types of ignition modules available on eBay? Is the leg spacing different, or are they designed for different diameter flywheels?
Found an exploded diagram.
https://www.dewilgo.de/hersteller/TECUMSEH/SPECTRA_E-58_E-58002A_MOTOR_TECUMSEH.pdf
Seems the part number is 14160034 by Tecnamotor.
From doing more searching, it seems a 34443 34443A 34443B 34443C 34443D ignition coil replaces this part.
Available for $10 on eBay - Delivery will probably take 3 weeks though! By then the grass will be 1 foot tall....
