Repairs Husqvarna z4217 Pump Pulley removal??
BINKOBA
I lost all the oil from somewhere underneath.
I suspect one of the pumps.
My question is how do you remove the flimsy metal pulleys from the pumps underneath.
Ashely
mechanic mark
BINKOBA
Thanks, but a couple of things, one is that is not my mower, my pulleys are underneath with separate pumps mounted on top
I have tried many times with the three jaw puller, and he flimsy metal pulleys are just bending.
Thanks
Ashley
reynoldston
I know what you are saying about the pulleys bending. What I have done in the pass is drill three holes into the pulley as close to the center hub as I can. Then take a three bar puller with bolts and nuts and pull from there. You might want to also put some heat on the pulley hub as you pull. Even at that I have had to cut the pulley off the shaft and buy a new pulley.
Use a rattle gun on the puller the jerky motion also makes a big difference
