Husqvarna RZ4623 - Throttle Cable - Wrong Length?
nevils
I just received this and it seems to be 6-8" too short for the RZ4623.
Husqvarna Part Number 539112734 Cable Throttle Model 966550301
(Please see pic show where existing front assembly and where this one comes up short.)
Does anyone one know what is the correct throttle cable assembly part number, please?
Thanks!
EDIT: Fixed model number. Also, this is the one that I bought: https://www.amazon.com/dp/B013TD0LQW
Please post an image of the serial number tag. RV4623 is not coming as a valid model number here.
nevils
Sorry, I fat-fingered it - should be RZ4623.
I am coming up with 539102732 superceded to 597524002
Got post what variation you have. There is at two different throttle cables
The engine tag says 2012. I'm not sure how to read a date out of the serial number tag. (I bought this used.)
On the model number tag there is what you would call the model number in your case is RZ4623 What we are looking for is the 9 digit number that is also on that tag along with the serial number. From a dealer standpoint that 9 digit number is the model number not the RZ4623.
If you look at Startech's last post it list model numbers starting with 966 or 967 that is the number he is referring to. And is located on the model/serial number tag.
nevils
