Husqvarna fuel problem
Ampman02
I have a Husqvarna YTH24k48. It suddenly died while mowing. I have changed fuel pump, filter and plugs. Even ordered a new carberateur with a new fuel shut off solanoid. It will only crank with the choke on and even then only runs a second and dies again. It won't crank at all with the choke off. Any suggestions?
If you remove the fuel line what kind of flow do you get out of the tank. Is it a full line flow or just a slow flow. I just went through this with a 46 inch model about a month ago. and the fuel outlet on the tank was clogged with grass that had fallen in the tank when the customer refueled the mower.
Ampman02
Thanks for the input. It was the solenoid. I clipped it off and cranked right up.
