mountman62
- Jun 10, 2013
- 1
- 1
Hello, brand new to the site, purchased a used zero turn yesterday, my first, yeh, 26hp B & S 54 inch cut, mower will turn over, but will not crank, will fire off on starting fluid, so I know it is a fuel issue, i have fuel pumping thru the fuel pump when turning over, i pulled the carb & checked all of it, looks ok to me, there is a solinoid on the bottom of the fuel bowl, What is the purpose of it, the rod on it is bent, but I still don't see why it shouldn't crank unless this switch is bad, do i have to replace the whole carb or can i just get the switch or bowl, i would think that this still wouldn't keep it from cranking if it will fire on starting fluid, any help would be greatly appreciated, he also said he thought the PTO switch was bad, looks like this mower has been sitting up since last year
