superiorGRASS
- May 31, 2014
- 3
- 22
What can i do to kill off a big fence line of poison sumac for good??
Gly 4 Plus has killed everything I have sprayed it with including poison ivy, sumac, and oak around trees and really put a hurt on the briars, it did not kill the briars out but it stopped all growth and dried them up for a string weed-eater to take them out no problem. Now I mix it stronger than the instructions, I buy it in the 2.5 gal jugs and mix 20 ounces of Gly 4 Plus with 15 gallons of water, which I think the instructions say 3/4 ounce per gallon. Gly Star also seems to work however it takes twice as long for some reason to work and show results.
I add a little dish soap to it. Helps it cling to the vines better.
Oh really, thanks for the info how much would you add to 15 gallon?
I mix 5 gallons and put close to 2 tablespoons.
So close to 6
And I will be nice and tell you don't add it before you add the water.
