nicholasbchavez
- May 13, 2017
- Threads
- 1
- 1
how to check for spark on a Briggs and Stratton 5.5 lawn mower engine?
Teds, there are a lot of ignition modules on lawnmower engines that will not produce a blue spark. Just not enough voltage created. Also grounding a plug on the head is not always accurate. Some plugs will spark against the head and still be bad. Heck some ignition modules will produce a spark at the spark plug and still be defective under actual work conditions.
