Kubota 3 cyl, water cooled, gas engine. This engine is on my Grasshopper 725. When I changed the oil and filter, after about 10 hours later, while mowing, the engine hesitated for about two seconds and a big puff of blue smoke came out of the exhaust. This happened four times during my 2 hours of mowing. This happened once before about two years ago after an oil change. My Kubota engine manual says 3.25 liters or .859 gallon, which converts to 3 quarts and 14 ounces. The dip stick does not have a "low" mark and it is completely covered when I remove it from the block. No other ill effects. Can this be over-fill??
