reynoldston
- May 23, 2011
- 92
- 5,705
WOT (wide open throttle) When I mow I always mow WOT. I figure that the equipment was designed to get max efficacy from WOT. The ground speed I regulate with the transmission. If the governor is working right you won't over RPM the engine.
