My John Deere 145 bracket came out of the slot on the PTO clutch and that caused the wiring coming to the clutch to be pulled out and wrapped around the pto clutch . Is there a diagram anywhere I can look at to rewire this . Thank you
What I know is that this failure generally means a new clutch
assembly is coming up for you. The new clutch will have
the required wiring.
What you will need to do is protect the wiring harness so
this failure should not occur again.
