How do I change hydro-gear trans oil?
Craftsman Garage
I have a Craftsman PYT 9000 model no 247.289800 that I think from my research has a hydro-gear trans on it, and when I’m driving (except for frat area once it gets some speed) it will make these low pitched whining like sounds, it’s when I first press on the pedal and when going on a even slight incline. Assuming it needs a fluid change. Not really sure how to do it as I have never really done maintenance on one of these transaxles. My question is how do I change the fluid in it, is that what you think is the problem, and do you think something else could be wrong with it?
Craftsman Garage
UPDATE: This is a hydro gear 618-0319 transaxle
Tiger Small Engine
