First advice was bad float/setting, so tried cleaning the carb, same thing.
Then I found where someone said clogged gas cap, cleaned that out, and also tried just running with the cap loose, same result.
So I ordered a new carb and air filter for it, installed today, same result.
Thought maybe clogged fuel line. Seemed to be trickling plenty, but popped off the line to the tank, found a tiny inline filter, tried removing that, put it all back together, still same result.
Any other suggestions?
My rebuild kit did also come with a spark plug, which I'll likely try, but I don't see how the sparkplug could do it, let it run great for half a minute or so then die abruptly.
Just seems like it's running out of fuel, but maybe something else that I'm missing?
