Hi. I'm a newbie here. Engine wouldn't start- probably because I over filled with oil and it ran into cylinder and then into carb-jet-fuel bowl.
I took off carb, flushed out oil, but now engine surges, however NOT if the choke is held in (this engine has spring to open choke).
Looks like governor rod is hooked up correctly.
Do I have a dirty/fouled jet, or is it something else?
PS last year same engine wouldnt run without the choke and I took it to small engine guy who simply replaced the carb- I thought that was pretty crude but they are $35 from Sears.
Thanks
Thanks
