basstracker
- Jul 9, 2013
- 19
- 51
I was given a honda presure washer, I cleaned the carb and got it to run a little but its pulling oil into the carb. what will cause it to do that. thanks
Bad rings but it would not run if the rings were that bad. Explain pulling oil into carb. From what side?
you guys were right on it, I pulled the air filter out started it up and it ran good, I put the filter back in while it was running and it chocked it down. I put a new filter in and it runs good. thanks for the help.
