bradcash
- Aug 1, 2010
- 12
- 25
For 15 yrs I have mowed with a John Deere 15hp 42" at work and a Murray 16hp 46" at home. With the JD it leaks grass out the left side under the deck and doesn't "lift" the grass for a smoother cut. But the Murray is much better and you get a smoother cut and no grass shooting the wrong way. I was puzzled for a while about this lift. The blades on both mowers are high lift. I finally felt where the blades on each mower were compared to the deck. The Murray blades were up about an inch inside the deck. The JD's blades were even with the deck. If you are buying a mower make sure the blades are up inside the deck.
