al christy
- May 25, 2015
- 1
- 2
mower refuses to start even used ether , cleaned plug. It was really close but stopped.help al:confused2:
Ether was never suppose to be used in gas engines, it was designed for cold weather starting of diesel engines only. To much chance of getting too much in and doing serious damage.
There is where the problem lies. What is a light pass? It could mean this amount to you and that amount to someone else.I guess we disagree here. In all my years of using starting fluid I have never seen any damage. I always have a can of it in my shop. All it takes is a lite pass by the air intake just to get the engine started. You don't run the engine off it.
And this scenario is often the case. It fires and wants to run but just doesn't quite do it so just a little more will surely make this ole girl go. That made her sound like she may mean business so lay down on that squirter and the next thing we know the plugs are screwed up and back to square 1.
Thanks but no thanks, I'll stay with my gasoline priming.
