dixiebonsai
- May 9, 2014
- 6
- 13
Anyone ever tried to helicoil insert in a briggs block? I was trying to get rid of the dreaded "new and improved" autochoke on a Briggs Quantum. Why do they always want to "new and improve" reliable , proven systems?My friend gave me the mower because thermostat on autochoke was sticking , causing it to only start when cold.I'm lucky he didnt take a hammer to it.If he stopped to go get a drink of water it refused to start until it cooled down.We ,as mechanics, all realize that it was flooding it because it was choking it when it didnt need choke.He was a non mechanic type.My redneck answer, rip all that $#^# off, put on primer bulb or throttle cable carb and away we mow.Well, thermostat is behind exhaust, to get it off I had to undo those bolts, like all exhaust bolts, heat had seized one.It sheared off.Now I realize I should have left it alone and just removed the arm and autochoke carb, Anyone have a procedure that helps seized bolt come on out so I dont do this again in the future?Ive tried welding a nut on stud couple of times, I'm down to very little stud left sticking out,afraid to try EZ-OUT, I'm sure that will break,then I wont be able to drill it out, so I'm left with helicoil.
