OK, my 99 Lazer 60 CH25S was running great till this w/e. It runs fine till all at once it shuts down like somebody turned the key off. Went through the fuel system, new fuel filter, switched tanks, even replaced the pump NO JOY. So--here is what I've narrowed it down to. I can run it all day long IF I don't turn the mower deck on. Moving or not makes no difference, it will shut down after a minuet or two. If I catch it, and turn the mower off, it's like somebody turned the ignition back on.
So--safety switch?? anybody experienced this?? All suggestions appreciated.
